kcsupra
Sep 29, 2016Guide
New Orbi setup Issues
Received my Orbi yesterday and had some install issues along the way. I followed the Quick Start Guide and got my Orbi at a point to login to the admin portal. For some reason I was unable to get in...
jbvdw
Nov 28, 2016Initiate
How do you reset the wireless channels??? I am having some of the same issues... keeps dropping my devices and haveing to reconnect again.
peteytesting
Nov 28, 2016Hero
jbvdw wrote:How do you reset the wireless channels??? I am having some of the same issues... keeps dropping my devices and haveing to reconnect again.
you dont reset them but you can change them
go to
basic / wireless
change 2.4 gig from auto to say ch 1 , 6 or 11
change 5 gig to say ch 44
see if that helps with the wifi connectivity issues
pete
- juheimbuDec 18, 2016Initiate
I'm also having this issue (firmware 1.4.0.18) after having set the radios to fixed channels. Any other suggestions? Randomly losing my internet connection is no good.
Thanks!
-juheimbu
- DarrenMDec 19, 2016Sr. NETGEAR Moderator
Are these drop out happening on specific devices like IOS devices? I have seen some customers say they have had problems with IOS since going to .18 firmware but if they roll back to .16 it is fine.
DarrenM
- thedonvaDec 20, 2016Guide
How exactly do you rollback to.16? My wifi speed has dropped dramitically on my macbook pro and my netflix (ethernet) resolution is terrible.
- graphicidentityFeb 12, 2017Guide
Just got my Orbi and set it all up. The speed is good when it works. But the signal drops out like crazy every 5 seconds it seems. I can't work. Can you offer any other tips? I tried changing the channel to everything available. My wifi issues have now plagued me for months.
- peteytestingFeb 12, 2017Hero
graphicidentity wrote:My wifi issues have now plagued me for months.
then the issue is not the orbi but something in your local enviorment that is causing issues , be that too many other wifi transmissions around you or some other form of interference
do a site survey and see what else is around you , use something like inssider to see the graphical signals
- thedonvaFeb 13, 2017Guide
I ditched my orbi in favor of Google wifi but that's because I have an ethernet backbone that allowed me to connect the Google wifi devices together.
