kcsupra
Sep 29, 2016Guide
New Orbi setup Issues
Received my Orbi yesterday and had some install issues along the way. I followed the Quick Start Guide and got my Orbi at a point to login to the admin portal. For some reason I was unable to get in...
thedonva
Feb 13, 2017Guide
I kept the three orbis for a while but the speeds were terrible. I tried troubleshooting with tech support. Tried different firmware versions. My Google wifi (3) work great. I'm getting phenomenal speeds but like I said I do have them bridged.
graphicidentity
Feb 13, 2017Guide
Can I ask how you have them bridged? I've never quite understood bridging. How is that different?
- thedonvaFeb 13, 2017Guide
graphicidentity wrote:Can I ask how you have them bridged? I've never quite understood bridging. How is that different?
So - bridge is not the correct term, I meant backhaul. This article explains the difference between the Orbi and Google Wifi:
http://www.wegotserved.com/2016/12/19/review-google-wifi-part-2/
I just did a speed test and my download is 119.58Mbps using my Google Wifi. I was getting 15Mbps with the Orbi. I almost think having multiple Orbis caused interference problems.
Something interesting I learned from the Orbi tech is you have to be at least 10' from the Orbi router, try running a test standing close and then further away.
Don
