BretD
Jan 11, 2018Administrator
New Orbi WiFi Kit: Compact Orbi Router & 2x Orbi Wall Plug Satellites - RBK23W
Better WiFi. Everywhere.
NETGEAR's New Orbi WiFi System (RBK23W) AC2200 is a kit of three devices covering homes up to 5,000 square feet with strong WiFi signals. This kit includes 1 Orbi RBR20 Router and 2x Orbi Wall Plug satellites RBW30.
Orbi RBR20 Router
The new RBR20 router is compact and has one Ethernet uplink and one Ethernet downlink port. It's great for a setup with very few hardware devices but heavy WiFi users. The Ethernet Port can be expanded with more ports later with any standard Ethernet Switch such as the NETGEAR GS908.Orbi RBR20 Router
Plug-in Strong WiFi
In a hallway or kitchen, garage or basement, the Wall Plug Satellite only needs an electrical outlet to deliver great WiFi. Easily extend WiFi coverage to every room of your house.
Sort By
- nXXoApprentice
so start by running your rbk50 properly before selling another one.
- BretDAdministrator
So sorry you are having an issue. Please upgrade to the new Orbi Beta firmware through the manual upgrade process. Feel free contact NETGEAR Support if you’re having issues with MR 2.1.1 (even if you’re outside of the 90 day window).
- aani75Apprentice
There are already 250 comments regarding ongoing issues with this beta and how unstable ORBI is becoming. https://community.netgear.com/t5/Orbi/OrbiOS-2-1-1/td-p/1476960/page/11
I agree !
pay more than 500$CAD and i have 10 disconnection per hours ....
- Get your Orbi system to run without needing a factory reset every week first!!!! I need to do that since I got your system almost a year ago. I have never seen such an expensive system with such low quality.
- sleepr88Apprentice
Netgear, since you can't seem to fix the Orbi, are you going to start issuing refunds? or exchanging everyone to Orbi Pros (which doesn't appear to have these problems, because you value business customers over regular consumers?)? and you think anyone will buy this when you can't even get the original systems to work correctly anymore?
- Lssandoval09AspirantI have had 0 issues with my Orbi - not sure what you guys are doing or if you just got a bad batch. The worst thing I’ve seen is devices attached info not showing correctly. WiFi super fast and reliable. No issues at all in AP mode with RBK50 with one satellite. Latest firmware as well 2.1.2.18
Hello,
during the last two weeks now I've only had two reboot
I think everything is back to normal, with the latest Google and Netgear updates
the issue was during October to mid-January
Thank you
- jdunne27Initiate
I bought the RBR20 with two additional satellites. Cost was about $350ish through best buy. This was the worst investment I have made. I can not stress the amount of troubles that I have had with this device. The troubles I have had include consistent drops of wifi, very slow upload/download speed, and very very poor performance with the app they have for the phone. Like any regular buyer, I contacted the NETGEAR support number, whose performance is as bad as this device, 3-4 times. Each time they tell me to get on the orbilogin page check/uncheck boxes, unplug router for 3 minutes, re-position the satellites, then tell me I should not have anymore trouble. Well, here I am for the 4th time calling during the middle of the week at midnight, with the same amount of trouble I have had 2 weeks after buying the system 2-3months ago. (February/march 2018)
This last phone call is a representation of the device. I called and told the support worker that I am having trouble again, he told me they would replace it for me. So I was ok with this. Thinking they would just mail me a new one and I would send in my old one. WRONG. They told me I have to fill out a paper work by mail, then pick my options on there, mail it back in, then wait for a response? Are. you. kidding.
The second to worst part of this phone call was that he had me on hold for about 15 minutes to come back and tell me that they dont have any of the RBR20 IN STOCK. IN STOCK, NONE AT ALL. So now, I have to call them back in 24-48 hours to see if they have it in stock.
In shock, I asked the customer service guy if I could speak to a supervisor because I just couldnt believe they did not have it in stock, I HAD TO ASK HIM 10 TIMES TO SPEAK TO A SUPERVISOR. He kept referring me to there consulting team, repeatedly. Finally, spoke to a superivsor and he told me that this situation of not having it in stock does not happen. Well guess what buddy it did.
The SUPERVISOR admitted to me that there was nothing they could do for me at this time. Coming from a supervisor in customer service, that is very very bad.
SO to all of you thinking of buying this device or similar devices which might have to go through customer service, do not buy it. Save yourself the hassle, the money, and the unreliability of this device. I would rank this device negative one stars. I will update on how the service is moving forward. It does not look positive.
