netgearguy
Dec 12, 2017Apprentice
New RBK30 - what is the safest newer FW version?
I've just set up an RBK30 (RBR40 & RBW30)...just blown away by the speed improvement over my older Nighthawk R7000. DId not know I was living in the dark ages. :) I'd like to update the FW. I cu...
netgearguy
Dec 15, 2017Apprentice
OK, son took a break, dad jumped in like a superhero to install the Eero. So far so good.
The pros:
- The hardware looks good (not cool, but at least good), nice simple design
- Small form factor - both router and beacon are signiificantly smaller than Orbi (the router is maybe 1/5 the size of the Orbi tower) and the Eero satellite/beacons are smaller/sleeker and less obtrusive as well. The smaller form factor of the router is helpful in our office where space at the desk where i have my networking base setup is at a premium.
- Beacons have "night lighting" feature I particularly like - the bottom of the unit has a build in LED light that works very well for the one placed I have in a hallway, and you can disable it if you like, set it it to a schedule, or light up when ambient light is low
- Speed is on par w/Orbi so far overall - might give a slight edge to the Orbi (and to give credit where due, the Orbi was only using a router and one beacon)
- No drops (but it's been all of about an hour and a half since i set it up)
- Potential add on services - including VPN, PW manager, ad blocking (I know, they are turning me into an annuity!). The cost is cheap enough at $100 a year and would have the benefit of me not having to spend any significant time setting up, administering and managing them. I was already looking into moving to a password manager and VPN options for my family anyway.
The cons:
- No web interface for router management! This surprised me. Web access could come, but who knows. The Eero mobile app is pretty good, and allows a fair amount of customization, but I really want a web interface to the router
- I got stuck during initial setup when I was adding the beacons...there is a screen in the add beacon flow where the "Next" button is hidden below the bottom of the screen. You have to scroll down to see it, and there is no indication that the scree scrolls or has more content below. Actually got stuck there and had to call support to get past that issue.
- Router did not default to "traditiional" DHCP lease range starting from 192.168.1.2..but you can set DHCP range in Network Settings>Advanced>DHCP and NAT, and also reserve IPs, etc. in Advanced settings. I have a few devices that are mapped from family computers so I want to keep them on 192.168.1.x IPs and I don't want to have to re-do mapping when I switch routers.
- Significantly more expensive than the Orbi RBK30 - $249 for the Orbi w/one beacon vs. $349 for the Eero w/two beacons. I could have gotten the $249 Eero system w/one beacon, but decided I wanted the "insurance" of the extra beacon as the number of devices and our internet use seems to persistently escalate.
tagteam
Dec 15, 2017Virtuoso
You might want to check out their community (if you haven't already done so) and take a peek at their list of feature requests (link below). It doesn't appear as if they have any plans whatsoever to implement a web interface. It might not be in your case, but that is a deal breaker for me. So, if I ever have similar issues with Orbi, I plan to pack it in and just get a regular tri-band router and probably one or two of those X6S (EX8000) range extenders. Good luck with your eero system.
https://community.eero.com/t/y7t861/list-of-current-feature-requests
- netgearguyDec 15, 2017Apprentice
Quick update - Going on 7 hours later and no drops, solid connectivity w/the Eero.
- netgearguyDec 16, 2017Apprentice
Next morning. Zero stability issues - connectiity has been consisten/uniterrupted.
However, speed tests using speetest.net app in my normail locations have fallen.
At the end of the day I was in the 70 to 80 range from a location in my house that I work from. That's lower than I saw w/the Orbi, which was up to 90 and more in the same location.
This AM i'm in the 30's to 40's earlier today, now back up in the 70's/80's.
Orbi was more consistent in terms of speed while I had it set up, but dropped connection repeatedly. Eero has very reliable connectivity, but appears to be running at lower overall speeds, and speed is less consistent.
I've ordered another Orbi RBK30 system from Amazon (first one came from Best Buy) and will try it to see if I had a HW lemon the first time...there are many positive reviews on Amazon for the Orbi RBK30 system, including ones from folks who say they've updated the FW. So if I get a "good" unit I might get both higher speeds and reliable connections w/Orbi.
Obviously sitll undecided on Eero vs. Orbi.
- netgearguyDec 17, 2017Apprentice
Day 2 on Eero. No drops, no issues.
Speed test this AM:
70-75 mbps on Galaxy S7 Edge/Nougat
120-130 mbps on Nexus 6P/Oreo
90-100 mbps on iPhone 6Pj
- Retired_MemberDec 18, 2017
what did the eero cost you?
how many ethernet ports in the entire setup?
- netgearguyDec 18, 2017Apprentice
$349
Two ports on the router, none on the satellites (called beacons by Eero) which was fine for me as I didn't need/use the ports on the Orbi satellites. So you have one port for the WAN connection, and one port out to a single wired device, or to a switch to connect more wired devices.
A multi-port switch by the router is a must with Eero if you have multiple wired devices. I already happened to have an 8 port switch in my system right next to the router, so the lack of ports on the router was a non-issue. You can pick up a switch for a few dollars if you don't have one, obviously.
You can also get what they call a Eero Pro system, which essentially is just three routers, rather than one router and two beacons, or one router w/one beacon (which is $249). Almost $500 for the Eero Pro system seems way over-priced IMHO.The Orbi HW definitely provides more bang for the buck w/four ports on the router and one each on the satellites that the RBK30 system provides, for $249 (and on sale recently at $199). Orbi support was also much easier to get to than Netgear support where I waited on hold for over 30 minutes when I called them. Eero support wait was a few minutes. Once connected the support experience was very good w/Eero, but it was almost as good with Netgear. But the long wait w/Netgear was really annoying.
But disconnect/reliability issues (and unclear if that's entirely a FW issue, or a combined FW/HW issue) made the superior HW features on the Orbi a moot point for me.
netgearguy wrote:$349
Thanks...that's a fair price. I'm currently not having any issues (other than the constant blue light on one of the sats this morning). I do use 2 of the ethernet ports on the router and 3 on one of the sats.
- tagteamDec 18, 2017Virtuoso
VAJim wrote:
...I'm currently not having any issues (other than the constant blue light on one of the sats this morning)...Shot in the dark, but is the "Enable Daisy-Chain Topology" box checked (under Advanced>>Advanced Setup>>Wireless Settings)?
- Retired_MemberDec 18, 2017Did the power reset. No luck. Blue light came back on. The daisy chain is enabled
VAJim wrote:
Did the power reset. No luck. Blue light came back on. The daisy chain is enabledAre you using the Star Topology or Daisy Chain? If you're not using Daisy Chain, try unchecking that box. After my Orbi system auto-updated to v2.0.0.74, that box was checked and the blue light illuminated on my Sats. Simply unchecking the box caused the blue light to turn off.
Thanks
Doesn't matter now. I left it alone for about an hour. Cam back and now the blue light is off.
Someone said in here that it's because the sat changed from 2.4 to 5g.
So how did that happen and what's that got to do with the blue light staying on. I didn't do anything? Been running fine for about 3 weeks then this.
Retired_Member wrote:...So how did that happen and what's that got to do with the blue light staying on...
A mystery of sorts. All I know is that the blue LED disappeared after I unchecked the Daisy Chain box. I suppose if a Sat is too far away from the router to utilize 5G for the backhaul, then it will use 2.4G and, again I suppose, the blue LED will appear (just not 100% sure about that).
- Retired_MemberDec 19, 2017
as of this morning the blue light on the sat remains off. I guess the power reset did the trick. Now I have a whole new problem and this has been discussed in another post.
I have a device (Lacrosse weather station - C84428) which requires wifi setup through your iphone. The iphone must be on a 2.4g network. well now my iphone only connects to 5g. so now the weather station will act as a stand alone with no updates from the NWS.
This can't be an isolated situation for i'm sure there are many devices on the market that require a iphone connection through a 2.4g network
- netgearguyDec 19, 2017Apprentice
Replacement RBK30 arrived from Amazon.
Set up and updated to newest FW, which as of today/yesterday is:Router RBR40 RBR40 V2.1.1.16
Satellite RBW30 Orbi Satellite-1 V2.1.0.18 So an even newer FW for the sat than for the router.
We'll see how things hold up and if the intermittent network drops resume as w/my previous unit.
Two restarts since I set up the new system w/the new firmware.
Not looking good, probably going back to Eero.
- netgearguyDec 20, 2017Apprentice
After more intermittent network drops, and then coming home from dinner later in the evening to find the network doing its disappearing/reappearing act once again, my wife called on her executive powers to veto Orbi in favor of "The other one that works." (I.e., Eero.)
So we're back on Eero. My return window on this second Orbi unit is mid-Jan, and I've updated status w/my level 2 support contact at Netgear in case he has any new suggestions beyond resettinng/re-FW-updating/rebooting, re-changing settings and other re-stuff that hasn't helped so far. Not exactly highly optimistic at this point, for obvious reasons. - netgearguyDec 21, 2017Apprentice
Per Netgear Level 2 support request on my case, I've set up my Orbi RBK30 system again.
Also per request from support I've made the following changes to defaults:
- Reset both router and satellite (two times on each)
- Left all defaults in place, except:
- Turned off Daisy Chain Topology (one satellite, don't need it)
- Set 2.4 GHz to channel 11 (least congested) rather than leaving at "Auto"
- Set 5.0 Ghz to channel 48 (least congested) rather than leaving at "Auto"
Both devices are on the most current FW releases available:
- Router (RBR40) is on: 12.1.1.16
- Sat (RBW30) is on: 12.1.1.18
I have the router sitting three feet away, and an iPhone attached to the network streaming audio so that I am aware when a network interruption occurs and I can see what the router is doing (rebooting or simply dropping/reconnecting).
I have only a few devices on the network. If it remains stable as-is for the next four or five hours, I will add all of my devices to it later today and see if it remains stable.
Hopefully this will be interesting and productive test.
Two hours later and there have been no disconnects or reboots.
Going to wait until after lunch, and if it is still stable, I'll connect all of my devices to it and see if stability remains.
Four hours later with no reboots or network drops
I've now enabled all my devices (total ~30) to connect to the Orbi network.
Monitoring to see if the surprising network stability continues...
- webminsterDec 21, 2017Luminary
18? Is that a typo, or did they give you an unadvertised new version?
- tagteamDec 21, 2017Virtuoso
That's the most current firmware for the RBW30 (wall plug satellite) that netgear guy owns.
Major typos - OOPS! Aside from providing the wrong version number I also put "12.1.1.xx" - adding a "1" in front of each version as well. DOH! Wish I could update old posts to fix stuff like that!
Actual FW versions:
Model Name Device Name Current Version Status Router RBR40 RBR40 V2.1.1.16 Satellite RBW30 Orbi Satellite-1 V2.1.0.18 Thanks for asking/pointing that out! :)
A little over two hours later an no drops.
I know - two hours is pretty insignificant amount of time, but previously I would have been expecting something to have happened by now.
Could the simple change of setting the channel manually to 11 be the key? Nothing else has changed as far as I know. Same FW as before, same HW, same settings except for manual channel selection vs. Auto.
Thar she blows...dammit.
Same as before:
- Notice losing connection on devices
- Check router - white flashing LED
- Check sat - purple LED
- All devices lose connectivity, wired and wireless
- Back online again after router finishes reboot and satellite reconnects
So looks like no improvement w/stability, at least none when a normal load is on the router.
I never saw CPU load go above 20% when I was checking it.
