twynne
Sep 12, 2018Apprentice
New RBK50 - Satellite won't switch to ethernet backhaul
Setting up a new RBK50 (one router, one satellite)... went through all the normal steps to set it up wirelessly first and upgraded firmware. Both report running firmware 2.1.4.16 and no further upda...
twynne
Sep 13, 2018Apprentice
Update: This problem seems to have resolved itself in that via the web interface I can now see that the satellite is connected 'wired'.
However, the Orbi app now won't connect to my Orbi system at all. It shows the window as if trying to detect what system I have and eventually errors out completely. Am I safe in assuming this is just an issue with the app as via the web UI all appears to be ok?
Also when looking at the attached devices screen in the web UI, all devices are showing as if connected to the router/RBR50 and none attached to the satellite. Even devices which are sitting next to the satellite! Is that normal?
