computerninja
Dec 11, 2018Guide
New RBR50 + Satellite setup - some thoughts and questions
Hey there everyone, this looks like a great community. Looking forward to being part of it.
I will start by saying I picked up a Used - Like New RBK50 from Amazon Warehouse for $281 the other d...
- Jan 24, 2019
Last I checked, after the Xfinity tech came over, post-installation of Gig speed, I was at 900+.
He basically came by to cap all the coaxial drops in my house that weren't being used anymore. I was having a certain level reporting as high that shouldn't have been.
He also replaced two coaxial terminations (ends) where the white plastic was "pushed in" some - which also leads to signal loss/leak.
Dec 11, 2018Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
- computerninjaDec 11, 2018Guide
I had edited my post and added this as you were replying:
I'm assuming that since the Orbi router is getting 100 Mbps via its speedtest, that the bottleneck is there? I should probably reboot my modem, for 734th time today?
Technicolor CGM4140COM.
The Orbi is running in router mode. The modem is running in bridge mode.
- FURRYe38Dec 11, 2018Guru - Experienced User
I believe your modem has a built in router already.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- computerninjaDec 11, 2018GuideThe modem does have a built in router, which is why I enabled bridge mode. Doing this disables the wifi radios in the modem/router combo.
