GregCook
Apr 26, 2020Guide
New to Orbi - RBK50 / RBR50 V2 - rebooting often
Hi All new to orbi and coming from a d7000 Have the RBK50 kit. Live in New Zealand. Have set up the router, did a factory restore and installed 2.5.1.8 firmware. Ran the unit withou...
Apr 27, 2020Guru - Experienced User
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
https://community.netgear.com/t5/Orbi/Orbi-Satellite-Drop-Connection-time-to-time/m-p/1890341/highlight/true#M88026
You can try Voxels FW for Orbi:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883615#
You can revert back to stock FW if it doesn't work out for you.
For doing any FW updates, I recommend avoiding the auto update FW section of the router. Many posters have had problems with this feature and is not stable to use. Seems to break systems or causes problems more than anything else.
First manually download the RBS and RBR FW files from here.
http://kb.netgear.com/en_US/000061838/
Unpack the FW from the .zip files.
Use a wired PC for this process. Safari(Mac), IE11, Firefox or Opera browsers are recommended.
Log into the RBSs web page and send the FW file there first.
Then send the RBR FW file lastly.
Factory reset the RBS and RBR and setup from scratch. After makeing sure the system works after setting up, be sure to make a backup configuration to file for safe keeping. This saves time if a reset is needed again.
GregCook wrote:Hi All
Ran the unit without the satellite at all. so we are talking a stand alone rbr50 essentially.
Went through and set up my device allowed DHCP starting at 192.168.1.10, set some reserved addresses for house alarm, printer, nas etc ( all in the .2 - .9 range ) also set up other items to have some specific reserved addresses higher up..
Had to do a manul configuration to work with our fibre provider, PPPOE
Have Enabled vlan bridge by tag group with ID 10. All required for spark in NZ.
Device connects fine, as do all the wireless and wired devices.
On 2.5.1.8 i found the router would reboot often im talking every 5 - 20 minutes, i then manually upgraded to 2.5.1.16 as that wasnt showing as an option, same problem, rolled back to 2.3.5.30 ( based on reading here ) had a stable connection for about 8 hours, now the device was showing a firmware upgrade to 2.5.1.16, so i did that using the auto update, seemed to work better however rebooting started again after 1 hour, ended up rolling back to 2.3.5.30 which is where i currently sit,
The device has rebooted after 3 hours this time, and right now has been running for 3. i did change the 2.4ghz band to site on 6 rather than auto as i read there were issues with that?
my device is also showing it wants me to upgrade to 2.5.1.16 which for now im not doing.
So ive read a bit about the device rebooting. this is a V2 model, could that come with issues? when its running it runs fine, speed and coverage is good, id be very happy with it, but when its rebooting often its infuriating..
could anyone tell me if setting up reserved addresses is a problem for this unit? im not a router expert, i have a mix of devices which dont use dhcp and for these devices i notice that they dont appear in my attached devices unless i reserver the same IP for them? for the rest i normally allow DHCP assignment, and just reserve the address for that mac address.
The logs are all but useless as they just show that the device has re initialised and the uptime is reset, i know there is a debug.htm page and wondering if i need to be capturing logs in there to determine whats going on? Does netgear look at those , could they help.
So really just looking for some help to stop rebooting. im guessing its down to a device trying to connect and crashing it some how..
hope you can help or provide some next steps i can review.
THank you
GregCook
Apr 27, 2020Guide
Thank you. This is the first sensible reply. I’ll report back on the details you asked for. In terms of locations the devices are about 30 feet. But You’ll also notice I said this was happening without satellites connected or turned on. So the distance shouldn’t be a factor .
More details to come
- FURRYe38Apr 27, 2020Guru - Experienced User
Keep us posted.
More details to come- GregCookApr 27, 2020Guide
Ok Some Responses.
Spark NZ provided ONT
https://support.huawei.com/enterprise/en/access-network/echolife-hg8240h-pid-8952145
"What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to"Basically exactly 30 feet. However when doing most of my testing it was done without the satellite to try and rule that out. I do have the satellite running now. Last night i got 8 hours on the device ( obviously no one using it ) this morning it crashed and has been up for 3 hours
"Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings"
all settings have been enabled during testing.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).All aside from the 20/40 have been disabled during testing. What is the 20/40 setting and also the preamble, how does that work, those two settings have not been updated yet
At this point when i received the Units the had 2.5.1.8 installed. I factory reset them before even starting. Other than to set up internet connection settings the device was factory, rebooting constantly.
I then manually installed 2.5.1.16 ( as the update link and check for new firmware found nothing ). after manual install similar issue.
rolled backwards to 2.3.5.30. This helped get the reliability up a bit, not as frequent a crash, but still rebooting everyfew hours. This was obviously a manual process.
did the check firmware and noticed it now was finding 2.5.1.16 as an option, figured id try that again using the auto update. NO good rolled back again manually
I should note that i have not factoy reset the device since the update to .16 and the rollback to .8 .
It seems to be that right now with teh RBR that regardless of firmward i am still having random reboots. Have set 2.4 to channel 6.
Not sure the best way to see other wifi points, assume the list in my laptops wifi list of available connections would be an indication, its not massive
Hope that helps with some details
- Retired_MemberApr 27, 2020
I'm wondering what you have learned from all of this?
