ArtLee
Jun 21, 2017Apprentice
Newbie questions
I'm three days into using my new Orbi RBK50. And, I have a couple of questions... Should UPnP be set to on??? Shoud I have Implicit Beamforming turned on??? And, Enable MU-MIMO??? Do I need t...
ArtLee
So, do I port forward? No, I don't even know what it is.
peteytesting
Jun 21, 2017Hero
thn i suggest you just leave UPnP tyrned on or you will have to port forward anything that need 2 way comms and that includes game consoles
- ArtLeeJun 21, 2017Apprentice
Yes, I think I'll just leave it turned on. Thanks...
- peteytestingJun 21, 2017Hero
i will say however make sure you have a good working paid for antiuvirus software on all your clients devices so bad software or viruses etc cant be installed on those devices which may then take advantage of UPnP to access the internet
