whoopa
May 04, 2020Follower
NG Orbi : Second satellites drops Wi-Fi speed
Hello,
I have a 200/200 fiber line. My modem is connected with Orbi router and they are in the same place.
From the Orbi router a UTP (cat6) to a switch (NETGEAR GS105 5-port) from the switch to my second satellite that one is on the 2nd Floor, so its a wired satellite.
The problem now is when i do a speedtest its stops at 90/40 if do the test at the Orbi router i get my 200/200.
I added some info about my Orbi.
Some screens of my Orbi
https://ibb.co/PtWVF0P
https://ibb.co/xsw8p0C
https://ibb.co/BgRsqVV
https://ibb.co/qDpfCC6
1 Reply
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
