Borggaard
Aug 24, 2020Aspirant
no 2 RBS50 limit speed
Hi I have just added a RBS50v2 to my network (RBR50+RBS50v1), but it seems to limited the speed on the new RBS. I have a 100/100mbit connects and when I’m only using my RBR and 1 RBS50v1 it all work...
- Aug 24, 2020
It certainly looks like that one cable is faulty. 99% of the time it is the cable termination that is bad, not the actual cable.
CrimpOn
Aug 24, 2020Guru - Experienced User
Borggaard wrote:I have tried:
-Switching the satellite -> did not work
-Connected the device directly with the cable for RBS50v2 and it shows over 100mbit -> so it is not the cable.
-Enable/disable Daisy-Chain Topology - did not work
-Switching from router to AP mode - did not work
When either satellite is connected using a cable installed in the wall, the speed drops to 10mb, but when the satellite is connected directly to the back of the router with a short patch cable it works.
How does this establish that the cable inside the wall is "good"?
- BorggaardAug 24, 2020Aspirant
The cables from RBS are inside the walls, but there are Cat 6a F/FTP LSZH - CU - Solid.
Do you think that is the problem? Can I fix that in some way?
