Borggaard
Aug 24, 2020Aspirant
no 2 RBS50 limit speed
Hi I have just added a RBS50v2 to my network (RBR50+RBS50v1), but it seems to limited the speed on the new RBS. I have a 100/100mbit connects and when I’m only using my RBR and 1 RBS50v1 it all work...
- Aug 24, 2020
It certainly looks like that one cable is faulty. 99% of the time it is the cable termination that is bad, not the actual cable.
CrimpOn
Aug 24, 2020Guru - Experienced User
Borggaard wrote:I have tried:
-Switching the satellite -> did not work
-Connected the device directly with the cable for RBS50v2 and it shows over 100mbit -> so it is not the cable.
-Enable/disable Daisy-Chain Topology - did not work
-Switching from router to AP mode - did not work
When either satellite is connected using a cable installed in the wall, the speed drops to 10mb, but when the satellite is connected directly to the back of the router with a short patch cable it works.
How does this establish that the cable inside the wall is "good"?
Borggaard
The cables from RBS are inside the walls, but there are Cat 6a F/FTP LSZH - CU - Solid.
Do you think that is the problem? Can I fix that in some way?
- CrimpOnAug 24, 2020Guru - Experienced User
