Borggaard
Aug 24, 2020Aspirant
no 2 RBS50 limit speed
Hi I have just added a RBS50v2 to my network (RBR50+RBS50v1), but it seems to limited the speed on the new RBS. I have a 100/100mbit connects and when I’m only using my RBR and 1 RBS50v1 it all work...
- Aug 24, 2020
It certainly looks like that one cable is faulty. 99% of the time it is the cable termination that is bad, not the actual cable.
Borggaard
The cables from RBS are inside the walls, but there are Cat 6a F/FTP LSZH - CU - Solid.
Do you think that is the problem? Can I fix that in some way?
CrimpOn
Aug 24, 2020Guru - Experienced User
