JanMoelbach
Apr 30, 2017Follower
No color on satellite on startup - dead unit?
Hi,
I just bought this system. The router works well, but I just can't seem to get anything working on the satellite.
When I power it on, the power LED turns green, and then nothing happens. The "ring" LED doesn't do anything. If I try to factory reset the satellite, I believe the power LED is supposed to blink amber or something, but it just stays solid green after holding down the reset button for up to 1 minute.
Do you think my sattelite unit is dead?
(I have also tried different power outlets, all with the same result)
- ElyLuminary
I would go to the store and get an exchange.
- DarrenMSr. NETGEAR Moderator
Hello JanMielbach
Yea you might want to swap the unit if possible if not contact Netgear support.
http://www.netgear.com/support/contact.aspx
DarrenM
