AdrianM
Oct 06, 2025Tutor
'No internet connection' attempted fix fail
Now I'm in a pickle. I've been suffering frequent losses of internet connectivity. All devices are accessible over the LAN but report 'no internet'. Power cycling the RBR50 restores connectivity for ...
Oct 06, 2025Guru - Experienced User
Does the top ring LED turn PINK or BLINK WHITE when this happens?
I've kept my 50 series at latest FW version and have not seen any issues. Possible loss of internet maybe at the ISP level.
RBR and RBS need to be at same FW level as well.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
If you havn't tried a factory reset yet, maybe time. A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite🛰
What channel configurations are currently set on the router?
Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
