SimonChurches
Jan 14, 2017Aspirant
No Internet on Orbi WiFi
Just got an Orbi router and satellite unit. The router is plugged into a Netgear DGN2000 ADSL modem and wireless router. The Orbi router has synced with the satellite unit successfully. I can see the ...
- Jan 14, 2017
Can you try accessing your modem page? most likely something like http://192.168.100.1 from there you can change its settings, do you have a device that can connect to the Orbi Network directly via Ethernet cable? also sometimes the issue where a specific device cannot get internet access is resolved by just making the specific device forget the Wi-Fi network, this can be done on the device's Wi-Fi setup settings, then once it has forgotten it try connecting to it again, you will again need to enter your password etc.
Ely
Jan 14, 2017Luminary
