wesleyrm
Apr 07, 2020Tutor
No longer can use Bluetooth with PC
Hello, I recently installed an Orbi Router and satellite. RBR50 firmware 2.5.1.8. It’s affecting the Bluetooth connection on my PC and not allowing me to connect my headset or mouse. I’ve never ...
- Apr 08, 2020
You can try lowering the power output of the RBR if needed and you think the Orbi is effecting your BT devices. Under Advanced Tab/Advanced Settings/Wireless Settings
wesleyrm wrote:
Hello,
It’s affecting the Bluetooth connection on my PC and not allowing me to connect my headset or mouse. I’ve never run into this issue before with a router or 2.4ghz. Checking online, I tried some solutions such as changing the channel for the 2.4ghz band. However this did not solve the issue.
Can anything be done to solve this issue? The satellite is in the same room as my PC, but if I turn it off and try connecting to the router, which is downstairs, I still have the same issue.
wesleyrm
Apr 08, 2020Tutor
FURRYe38 wrote:You can try lowering the power output of the RBR if needed and you think the Orbi is effecting your BT devices. Under Advanced Tab/Advanced Settings/Wireless Settings
wesleyrm wrote:
Hello,
Thanks! I dropped 2.4Ghz to 75% and my BT on PC now works and connects to devices again.
Apr 08, 2020Guru - Experienced User
Glad that worked.
Enjoy.
wesleyrm wrote:
Hello,
