Mr_bwd
Jun 15, 2020Aspirant
No signal on my rbs40v
Sinds last year i have the orbi rbk 50 (rbs50 and rbr50). last month I bought the rbs40v voice. The voice has been placed on the older rbs50 place and is often falling away in the connection. I have t...
CrimpOn
Jun 15, 2020Guru - Experienced User
Can you please report if the feature "Daisy Chain" is checked?
On the Orbi web interface, the Advanced Tab, Advanced Settings, Wireless Settings.
About 2/3 down the page, under the heading "Backhaul Technology".
The distance from ground floor to 2nd floor may be too far to get a good signal.
Mr_bwd
Yes, Enable Daisy-Chain Topology is checked
