Maderacopy
Apr 08, 2017Aspirant
No Such File or Directory
My Orbi connection works great on most occasions, however sometimes while browsing the web a site will give me "No Such File or Directory" If I switch routers I can visit the site. I also can't get N...
- Jul 18, 2017
I am no longer having any issues. I reinstalled my Orbi and everything is now great.
ESP23Hitman
Jul 12, 2017Aspirant
I have the same issue with my setup. I have Xfinity and am using their cable modem. I have the orbi connected to the modem amd set was quick and easy. I am able to connect to the orbi's radios, but there is no data flowing through. Every time i open up a webpage I get 'No such file or directory'. When i connected directly to the modem everything works fine. What am i missing?
DarrenM
Jul 14, 2017Sr. NETGEAR Moderator
Hello ESP23Hitman
Are you able to bridge the modem?
DarrenM
