Maderacopy
Apr 08, 2017Aspirant
No Such File or Directory
My Orbi connection works great on most occasions, however sometimes while browsing the web a site will give me "No Such File or Directory" If I switch routers I can visit the site. I also can't get N...
- Jul 18, 2017
I am no longer having any issues. I reinstalled my Orbi and everything is now great.
1bugboy
Jul 18, 2017Aspirant
- MaderacopyJul 18, 2017Aspirant
- JBXIIIJul 23, 2017Aspirant
Good day,
I'm having the same issue and using Orbi in bridge mode.
Since a couple of days, after a period of 1 month during which the ORBI was perfectly working well, now when trying to reach any of internet website using my devices iPhone and/or macbook Pro, it's not working and I receive the error message "no such device or directory" on the safari browser page.
Same when using either ORBI wifi or direct thernet connection.
When I'm using directly the internet box internal wifi, it's working well --> problem is the Netgear Orbi system.
Sometimes, instead of the above message, I have another message saying that the problem comes from "routerlogin.net" certificate not recognized and that the system "can't check the identity of the site".
I've tried to turn off / turn on the box and the ORBI I've tried to restart them and to reset them but it's solving nothing.
- DarrenMJul 25, 2017Sr. NETGEAR Moderator
Hello JBClll
Do you have your modem set to modem only or do you have the orbi set to access point?
DarrenM
