irish26
Oct 05, 2025Aspirant
No Wifi, but Ethernet works fine
Using the RBR50 and 2 satellites. I decided to switch ISP’s. Tech came out today and installed modem. It showed online but my Orbi wouldn’t work with it. So I decided to just go back to the old ISP’s...
CrimpOn
Oct 05, 2025Guru - Experienced User
irish26 wrote:hardwired devices having no issues
The Orbi router should appear to those devices as the Internet "Gateway" IP address. Much of the time this IP address is 192.168.1.1
"orbilogin.com" (also orbilogin.net, routerlogin.com, routerlogin.net) are fake URLs that are intercepted by the Orbi router, which returns the router IP address.
Are you able to determine the Gateway IP address and connect to it using a web browser?
