SomebodyInGNV
Sep 14, 2022Guide
noob help: OpenVPN on an Orbi RBR20
Hello. I enabled OpenVPN on my Orbi RBR20 using default settings, i.e., TUN on UDP 12973 and TAP on UDP 12974. I installed the OpenVPN client downloaded from OpenVPN.net with default settings. I ...
SomebodyInGNV
Sep 16, 2022Guide
I didn't realize config files were stored in user files. The dir I showed was from program files\OpenVPN\config.
I later got error messages saying there were multiple config files. Not knowing about the user files, I just deleted OpenVPN out of frustration, with plans to work on it another day.
Now I see there is a copy of client.ovpn in users\...\OpenVPN\config\client and another in program files\...\config. I'll reinstall OpenVPN, drop the cert files in the user folder delete the corresponding entries in program files.
ekhalil
Sep 16, 2022Master
Yes, please do that
