CWR
Feb 27, 2020Aspirant
NORD VPN - is there a reasonable priced router that works with it and Orbi?
Hi i have a very small consultancy in the U.K. and Italy and swop between locations - I chose Nord VPN as I am not tecky and the reviews were good, similarly I chose the Orbi RBR50 and mesh extender...
schumaku
Feb 28, 2020Guru - Experienced User
CWR wrote:i have a very small consultancy in the U.K. and Italy and swop between locations - I chose Nord VPN ...
Clive,
Just curious: What for exactly you (think) need a VPN?
CWR
Feb 28, 2020Aspirant
Fair question - I am an old(ish) manager of infrastructure projects who now part-time helps companies with project controls, strategy and enterprise risk advice. Some of the companies I support are very concerned about data security due to patents and licence information and recommend the use of a VPN and also have a list of approved VPN providers. As I split my time between UK and Italy - out of the list I chose Nord - I liked Nord becaue it regularly comes out well in the reviews and because friends recommended it.
Thanks
Clive
- schumakuFeb 28, 2020Guru - Experienced User
Clive,
This does not answer the question I'm afraid.
With these VPN providers you build a VPN tunnel to the provider ... and from there the connections go out to the wild Internet. 99% of this is for hide-my-ass or to have an IP somewhere in another country to access location limited services, like national TV services.A VPN (in business terms) is used to connect two or multiple sites, or to connect in a secure way to the corporate network, building a secure extension to your computer (or site).
Regards,-Kurt
- CWRFeb 28, 2020Aspirant
Sorry Kurt, I can't help, I just do what I am told. I can keep jumping in and out the VPN when I am working, it is just it messes with my Sonos and Google smart home stuff and so the Google community advised installing the VPN on the router. One consultant I worked with on the last job used two VPNs concurrently! Or so he said. Not my area.
cheers
Clive
- schumakuFeb 28, 2020Guru - Experienced UserSo your customer tells you that you need to use a crappy hide-my-a** VPN to have all your Internet traffic flowing over a third party VPN service? Beyond me.
I understand your customer(s) are requesting to use THEIR VPN to connect to their business network - this is what makes sense.
Similar, they might require that you are using VPN for accessing business/contract relevant date you might host e.g. on a NAS in one of your sites over the Internet.
Never mind, it was intended as a heads-up ...
