TomBertie
Sep 07, 2017Aspirant
Not getting a strong 5ghz signal from Orbi
I have an Orbi pair with RBR50 and RBS50. The Guest wifi is booming through at 5GHz but the private wifi seems to be weak in areas. Having done some analysis it seems as though one of the units isn...
Dustin278
Sep 07, 2017Apprentice
TomBertie wrote:I have an Orbi pair with RBR50 and RBS50. The Guest wifi is booming through at 5GHz but the private wifi seems to be weak in areas. Having done some analysis it seems as though one of the units isn't transmitting the private network on 5GHZ as can be seen from the attached picture (Guest network seen at -46dB [Strong] and -78dB [Medium] but Home only seen at -77dB [Medium]). You can see that all signals are visible at 2.4GHz. Does anyone have any ideas?
Yours, Tom
Probably issues with the firmware - what firmware do you have?
TomBertie
Both units have the current firmware: V1.12.0.18
- Dustin278Sep 07, 2017Apprentice
TomBertie wrote:
Both units have the current firmware: V1.12.0.18I would have to suspect that the buggy firmware has something to blame with this - V2 for the firmware has no ETA and could be weeks away - I would try and a different channel for 5gh or see if you are having any interference from neighbors WiFi
- TomBertieSep 07, 2017AspirantThanks. It isn't interference from the neighbors so I guess I'll have to hope the new firmware sorts it out. It's difficult to see it being a hardware problem given the guest network is fine, but I'm a little concerned that I haven't found any other reference to this type of problem
- peteytestingSep 07, 2017Hero
disable the guest wifi and see if the main wifi on 5 gig comes back
