TomBertie
Sep 07, 2017Aspirant
Not getting a strong 5ghz signal from Orbi
I have an Orbi pair with RBR50 and RBS50. The Guest wifi is booming through at 5GHz but the private wifi seems to be weak in areas. Having done some analysis it seems as though one of the units isn...
TomBertie
Both units have the current firmware: V1.12.0.18
Dustin278
Sep 07, 2017Apprentice
I would have to suspect that the buggy firmware has something to blame with this - V2 for the firmware has no ETA and could be weeks away - I would try and a different channel for 5gh or see if you are having any interference from neighbors WiFi
- TomBertieSep 07, 2017AspirantThanks. It isn't interference from the neighbors so I guess I'll have to hope the new firmware sorts it out. It's difficult to see it being a hardware problem given the guest network is fine, but I'm a little concerned that I haven't found any other reference to this type of problem
- peteytestingSep 07, 2017Hero
disable the guest wifi and see if the main wifi on 5 gig comes back
