nugen's avatar
nugen
Number of Daisy Chain satellites
With the new firmware update that enables satellites to dish chain. How many satellites are supported in a daisy chain on the RBK50 system.
Also is it possible to convert a router to a satellite if I purchase 2x Orbi 2-pack and want to end up with 1 router and 3 satellites?
Thanks!
  • It is not possible to run a router as an additional satallite - also let me warn you against running two orbi routers with 4 satellites on the same network - very bad idea that is.
    I've seen someone from netgear say that you can easily run 3 satellites, not sure if more are supported but probably just slows the system down.  Question is why would you need more? I have a 4500 sqft 3 story house and the RBK50 with two satellites has no problem covering the entire area and easily into my neighbors house across the yard.
    • nugen's avatar
      nugen
      It's for long hallways and where there's much concrete.
