jpbilderback
Mar 10, 2021Follower
Obri cbk752 - direct ethernet connection to satellite - SLOW - 10 mbps
S1arched But Couldn't Find Answer .
Setup Orbi Cbk752 Yesterday. Works Except One Desktop Computer Is Direct Connected Via Ethernet To An Orbi Satellite And Seriously Is Getting Speeds Of 5 to 10 mbps!!! I Think Dialup Was Faster!! Lol
Settings Seem Ok On The Oebi And The Computer, Tried Different Ethernet Cables... what Else Can I Do??
1 Reply
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the brand and model# of the adapter in this pc?
Is it rated for 1000Mbps connection rate or less?
Be sure the adpaters dirvers are up to date.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-SpeedTry disabling the following and see:
Armor, and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
