pugs's avatar
pugs
Follower
Dec 04, 2022
obri voice rbs40v
I got new internet and am trying set up the orbi extender/smart speaker and I keep getting a message that it is not registered, but it is and it won't connect
  • CrimpOn's avatar
    CrimpOn
    It would help to know more about "connect", as in:
    • The satellite will not connect to the router? or,
    • The satellite works as a satellite, but enabling the Voice feature creates an error?
    • CrimpOn's avatar
      CrimpOn
      KevinLiT wrote:
      You are getting this message because your device is not registered with NETGEAR.
      This seems inconsistent with Post #1 where he says "but it is and it won't connect".
      Also, I do not recall registering a product with Netgear being a requirement to connect it to a system.
      The Orbi app, which is essential for activating the Alexa part of Orbi voice absolutely requires a Netgear account login.
      Very confusing situation.
      • KevinLiT's avatar
        KevinLiT
        NETGEAR Moderator
        Hello Crimpon,
        Thanks for your post!
        Have you experienced this issue before?
        Best,
        Kevin
        Community Team
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hi Crimpon,
    Thank you for your acknowledgment!!!
    Best,
    Kevin
    Community Team
