Mgomez85
Aug 27, 2017Apprentice
Ok I gave in
I couldn't do it no more! My sat unit for the life of me just won't keep a constant throughout put my data stream just keep dipping!! I have full cover throughout my entire house so that's great but f...
DarrenM
Aug 29, 2017Sr. NETGEAR Moderator
Hello Believe85
Did you make sure beamforming was enabled? also did you try to uncheck the 20/40mhz option I know Iphones do not like to work well with the 40mhz.
DarrenM
