MartinPF
Oct 24, 2019Aspirant
One Device Connected to 2.4G
I have a device that can only connect to 2.4G band. Can I manually select the 2.4G Band for a specific device.
- ekhalilMaster
Orbi broadcasts one SSID for both bands. If the device only supports 2.4 GHz then it will see Orbi's SSID but will only attach to ´the 2.4 GHz band.
- MartinPFAspirant
My simple device (wifi controller for under cabinet lighting) uses Smart Life app (on Google play) and it only supports 2.4G and when I try to connect to the network is says it cannot because it only supports 2.4G.
- ekhalilMaster
Please try to -temporarly- disable the SSID broadcast for the 5 GHz, and try to attach the Smart Life device.
The SSID boardcast settings can be found under advanced wireless settings in the web GUI.
