bozhaobo
Nov 30, 2020Aspirant
One of 2 RBS20 satellite disconnect randomly
I have RBR20 + 2 RBS20 setup, with firmware v2.5.1.16 on all of them. the system works fine since July 2020, but suddenly one of the satellite randomly disconnect/offine multiple time a day. I tried power on/off, reset, sync ... but it will work for a little then offline.
This is no movement of the router and satellites and they stay in same location for months. the other satellite rbs20 works fine (so far) and no issue.
Can someone help?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026Try swapping RBS locations?
- bozhaoboAspirant
Thanks for the reply!
I swapped RBS locations and then move one to a higher spot and this time it worked - so far so good. Not sure why the location worked for the past 5 months and suddently not working but hope this time will last longer.
Maybe some sort of new interferences or noise.
Mark your thread as solved so others will know.
Enjoy.
