PhoenixV
Mar 15, 2017Apprentice
Opening Ports on Orbi
I need some advice on how to set up Port Forwarding for Wi-Fi Calling to work properly through Orbi. There are multiple phones that utilize this feature so I can't specify a particular IP address. ...
st_shaw
Mar 15, 2017Master
You cannot forward a single incoming port (e.g. UDP 500) to more than one IP address on the LAN. Think about it...how would the router know to which of your multiple phones to forward the incoming connection?
The only way this could be done is if you had multiple WAN IP addresses (one per phone), or if the connections are all initiated by the phones on the LAN (in which case no forwarding rule is needed).
You should review why you think this forwarding is necessary.
PhoenixV
Yes I suppose I might have to use a port trigger instead. As to why, as I said before, WIFI calling on our cell phones is dependent upon communicating through these ports, and since I have no service in my loction I am dependent on it.
