Nemelaer
Nov 19, 2018Guide
OpenVPN Not connecting in Orbi system
Hi, i have a brandnew ORBI RBK23 system (1 router, 2 satellites), router connected to cable modem. The ORBI router as replacement for a Nighthawk R7000, on which a VPN service worked flawlessly. Conn...
- Nov 20, 2018
FOUND IT! Thanks to you. I changed the settings of TUN back to UDP and now it is working all right! I forgot that I initially tested it over the home network and as you said, that does not work (but it did on my previous router, so that caused my confusion). When I set the wifi on my iPad to my smart phone 4G hotspot, it works fine now!!
The only thing that is still bothering me is the lg in the windows client (notebook with windows 10). Connection is achieved all right, but in the log I see this:
Tue Nov 20 10:03:33 2018 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Tue Nov 20 10:03:44 2018 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent thisShould I start a new topic on this, or may I ask your opinion about this too? (I tried to understand what is explained in the provided openvpn.net link, but can't get a grip on the contents; seems that I have to do a lot of programming, which seems very difficult).
But anyhow, by this conversation with you, my problems with the connection, anyway on my iPad as well as my android smart phone, are completely solved! Thank you very much!
Nemelaer
Nov 21, 2018Guide
I am very sorry your problem still exists...
Btw, your client.ovpn contains exactly the same lines as mine, only mine is one long line without hard returns (in notepad), and no spaces between the lines as compared to yours (where there are hard returns). I wonder why you apparently downloaded another format...
What exactly are the "new ERRORs" you write about in your last post?
Nemelaer
Nov 22, 2018Guide
Ah, now i can see the errors, but i do not understand them...
You have the exact lines in your (as compared to my) client.ovpn, and i also tried what would happen if i make it a file with neat 18 lines (the 18th being the added line remote-cert-tls server). No difference, works equal flawlessly.
The only possible difference (but i do not know its significance) is that you keep also a client file in the C:\users\(user)\openvpn\config? Because i have not (the only place is the C:\program files\openvpn\config, along with the 3 other files of course (ca.crt, client.crt and client.key).
If the problem still exists, you might try the good old reboot of your system and / or try the whole operation without the protection of firewalls etc.
I am afraid i can’t be of further assistance (being kind of a novice myself!)
Good luck, and please post again if you have (hopefully good) news flashes!
