beckss1's avatar
beckss1
Tutor
Mar 04, 2022
Optical connection
Dear gurus.,
I planning to change conenction from ADSL to optical and I see that in Orbi Router port is not exist. I also read note, that ORBI need to be connected via Ethernet cabel, but I see that exist many converters, for example
TP-Link Gigabit SFP to RJ45 Fiber Media Converter, Fiber to Ethernet Converter 10/100/1000Mbps RJ45 Port to 1000Base-SX Multi-Mode Fiber (MC200CM) Black
(link to Amazon -> https://www.amazon.com/TP-Link-Ethernet-Converter-Multi-Mode-MC200CM/dp/B003AVRLZI?language=en_US&th=1)
Then could I connect optic to this converter and take output to same port into ORBI router.
Thanks for willing to help
Best regards
B.S.
1 Reply
  • plemans's avatar
    Most fibre providers give you either an ONT or a gateway that converts from fibre to ethernet.
    Before buying anything, I'd check with your ISP on what they're going to provide.
