rrh770
Dec 27, 2018Aspirant
Optimal Settings for Orbi RBR 40 with ATT Fiber and Direct TV
I am currently running AT&T Fiber and DirectTV via a BGW210-700 Gateway. I purchased an Orbi RBK43 Wifi System to extend range and increase my bandwidth (RBR40 Router and two RBS20 Satellites.
rrh770
Thanks. Will try the settings for the Radio's.
>6,000 sq ft across three levels. Internet comes in at the edge of Level 1. I'm close to 30' straight up through two floors to one, and about 30-40 feet on Level 2. Both registered and turn blue. Would be nice if the indicator lights stayed on so you could always see the status.
Dec 27, 2018Guru - Experienced User
Ok, you should be good then. Ya, well if there was a problem in signal then LED on top would come on, Pink:
https://kb.netgear.com/000045868/What-do-the-LEDs-on-my-Orbi-Pro-devices-mean
Some users don't like it when the LED is always on. So NG had to compromise somewhere. :smileywink:
