drafferty
Aug 16, 2022Aspirant
Options for network/mesh upgrade
Hello
I have an older network/mesh system AC3000 with RBK50(1 router and 2 satellites) plus RBS50Y. What would be a good noticeable upgrade and are upgrades to new systems easy? Do newer systems download or import settings from older network?
Thoughts
I'm a fan of the RBK50 series. They work great. I didn't notice much difference going from my 50 series to the RBK750 series. I did going to the rbke963 series but that's a huge cost difference. And a lot depends on what your device is. Its not usually the router that is the bottleneck in speeds but your phone/tablet/computer.
What are you looking at upgrading to?
Or are you just needing more speed?
What are you using it for to need more speed?
- draffertyAspirant
As you stat I think it's the modem which is only rated at 120mbs but I get over 220. Cable company recommends an upgrade on that hardware which will support upto 1Gb but the basic servive I would recieve would still be 300mbs. With just swapping out the modem I should see some difference.
thoughts
- draffertyAspirant
overall , more coverage and at times tv streaming spins. I adding another rbs50 to other side of house along with the rbs50y out on patio.
use for streaming tv and some gaming.
What's the SQFT size of your home and how many levels is it?
