janrw
Jan 17, 2018Aspirant
Orbi - Configuring wired ethernet - backhaul and fronthaul
Dear Community, I am currently considering to buy an Orbi system and I was wondering: If satellites in the Orbi system are wired up via Ethernet Backhaul, is it possible to reconfigure the 5GHz ...
- Jan 20, 2018
Hi Darren,
Thanks for your answer!
If you get into a situation where all satellites are wired, it would still be a very nice addition to the product I think, if it would be possible to reconfigure.
Anyhow, I bought the product yesterday and I am very enthousiastic about it!
Thanks Darren,
Jan
DarrenM
Jan 19, 2018Sr. NETGEAR Moderator
No you can not do that as you can still have satellites on wireless backhaul at the same time another one is on wired backhaul.
DarrenM
- janrwJan 20, 2018Aspirant
Hi Darren,
Thanks Darren,
Jan
- IsamuraFeb 16, 2018Tutor
Darren, when the wired ethernet back is engaged on all satelites, does the 5gz back channel signal shut off? I ask because this higher frequency backchannel interferes with my wireless headphones (Astro A50s).
- DarrenMFeb 20, 2018Sr. NETGEAR Moderator
No it does not disable the wireless backhaul.
DarrenM
