IFlyNavy
Nov 23, 2016Aspirant
Orbi - iPhone 7 Plus can't connect
I can't for the life of me get my iPhone 7 Plus to connect. I intially was getting "incorrect password". I changed the SSID, and then it accepted the password but would never connect. Other device...
- Nov 23, 2016I'm an idiot and just figured it out. My current network is a Meraki Network. I had AirMarshall enabled. That was killing any connections to rogue APs, in this case the Orbi. I whitelisted it and I'm good to go. Can't believe I forgot about that security measure. Good news, it works. đ
TheEther
Nov 23, 2016Guru
Do you have any funky characters in your SSID or password? While technically any printable ASCII character is permitted, it's possible that the Orbi may not accept all of them. Start with something simple to get things working, like an 8 character alphanumeric password. If that works, experiment with more complex.
