Weisengrund
Jul 02, 2018Aspirant
Orbi - no internet no server
Using a macbook pro 2017
Fritzbox7490 Router
Orbi started well but fell apart overt time. Disconnections, poor quality, and now no internet at all. I've had it for about 9 months. Up and runn...
Jul 03, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
Any other wifi neighbors near by? If so, how many?
Weisengrund
Jul 04, 2018Aspirant
3-4 other wifi neighbours
