zowa's avatar
zowa
Orbi - Torrent and DNS problem
Hello,
I have the following problem:
Orbi (2 units) router mode. When I download something using a torrent client (uTorrent), the DNS name resolution stops.
The network connectivity goes on ok. I can access anything by IP address. And if I configure manually a different DNS server for my computer, it works just fine. The problem is that Orbi just stops wth name resolution.
I have to reboot the units to make DNS work again.
And guess what: I AM UNABLE TO CONFIGURE A DIFFERENT DNS SERVER USING ORBI'S DHCP, BECAUSE IT DOES NOT HAVE THE OPTION!!
Well, any thoughts?
Thanks!
    • zowa's avatar
      zowa
      Hello,
      Firmware V2.1.4.16.
      The orbi is connected to a simple ADSL modem. The problem is not with the modem, because I can connect a laptop to another port at the modem, and it works fine. Only machines behind Orbi are affected by the DNS problem, and only if they are receiving the DNS Server IP Address from Orbi's DHCP.
      The Orbi's DHCP configuration does not have an option to change the DNS server provided to clients. Really strange.
      My setup:
      ADSL Modem -> Orbi RBR50 -> Orbi Satelite (15 feet distance).
      • FURRYe38's avatar
        What is the Mfr and model# of the IP modem the Orbi is connected too?
