tln741
Nov 11, 2017Star
Orbi - why can't we change channels on satellites?
Wireless design best practice when installing multiple access points in an area is to have non-overlapping channels. So if you have 3 APs (RBR50, 2-RBS50) in an area, for 2.4 GHz, one AP would be cha...
NickC4555
Nov 12, 2017Star
With traditional domestic wireless extenders, each access point is a separate wifi network, so non-overlapping channels are a benefit. Orbi is a mesh topology, where each node (satellite) passes the signal from one to the next, extending the coverage of a single wifi network. Client devices don't have to switch from one network to another as they do with extender based networks.
tln741
Nov 12, 2017Star
That assumes optimum placement of APs operating on the same channel to avoid co-channel interference and excessive collisions. That is often not possible in real world installations. And that should not be the assumption by Netgear (just move the Orbi to an optimum location, not where you actually want it). Using the same channel does have the advantage of avoiding latency cost of channel switching when walking through the house, but most devices are stationary while in use.
In addition, in higher density housing developments and apartments, co-channel interference from a foreign WLAN near one Orbi could be different from the co-channel interference near a second Orbi.
So it would seem the best solution would be to allow the manual assignment of channels on the satellite.
