tln741
Nov 12, 2017Star
Orbi - why can't we change channels on satellites?
Wireless design best practice when installing multiple access points in an area is to have non-overlapping channels. So if you have 3 APs (RBR50, 2-RBS50) in an area, for 2.4 GHz, one AP would be cha...
tln741
Jun 18, 2018Star
That is how ORDINARY repeaters and extenders work. But the Orbi is not an extender or repeater. It is a mesh network with a dedicated backhaul link, effectively operating as if each AP had a wired connection back to a switch or wireless controller.
In a mesh network, unless the APs are optimally placed with sufficient separation to eliminate co-channel interference, there will be problems. This is almost never possible in a typical house. The only advantage of having the same channel is to avoid latency when a moving device changes channels/ap links. And I am not sure if latency is actually eliminated when AP placement is not optimal. For example, I have one unit on the first floor and one unit on the second floor - directly above the other. Because I want physical ports in those locations.
molec
Jun 18, 2018Guide
tln741, tried to give kudos on your posts, but doesn't seem to work.
do other "mesh wifi systems" also use single channel like the orbi or is the orbi an exception?
