tln741
Nov 11, 2017Star
Orbi - why can't we change channels on satellites?
Wireless design best practice when installing multiple access points in an area is to have non-overlapping channels. So if you have 3 APs (RBR50, 2-RBS50) in an area, for 2.4 GHz, one AP would be cha...
schumaku
Aug 26, 2018Guru - Experienced User
FURRYe38 wrote:
MESH systems are based on wireless extender and repeating design and methods. These use same channel connections. Been like this since the beginning.
Sorry, this does not make much sense - Orbi and Orbi Pro does much more than a Wireless Extender (repeater).
Orbi (most if not all versions) make use of a dedicated radio - thus Netgear does talk of Tri-Band - for the dedicated backhaul, nick-named FastLane3 Technology provides a dedicated WiFi Tx/Rx: 2x2 (866 Mbit link rate) up to 4x4 (1.7 Gbit link rate) in a Mesh. Different from a series of hard configured wireless bridges, the associations in a Mesh are dynamic and can change.
Unlikely they operate the backhaul radio and the 5 GHz front lane on the same channels - this is what a generic Wireless Extender would do (except if FastLane is enabled where one radio is used for a wireless bridge, and the other radio for the client access).
FURRYe38 wrote:
Besides if NG was to implement something to suite your needs, it wouldn't happen any time soon if at all on current product lines.
The Orbi access side is built with LAN ports and two dedicated radios, one on 2.4 GHz, one on 5 GHz on each router and satellite. Can't see why there should not be a possibility for implementing some channel optimisation and RRM (radio resource management).
astrojohn
Aug 26, 2018Tutor
I show the backhaul on ch 157.
