tln741
Nov 11, 2017Star
Orbi - why can't we change channels on satellites?
Wireless design best practice when installing multiple access points in an area is to have non-overlapping channels. So if you have 3 APs (RBR50, 2-RBS50) in an area, for 2.4 GHz, one AP would be cha...
molec
Jan 01, 2019Guide
FURRYe38 wrote:
Users need to remember that the reason why you can't pick channels on the satellites is that they are acting as REPEATERS/Extenders, thus when repeating, they have to be on the same channel as the source wifi signal channel. This doesn't work if the satellites was on a different channel from the source wireless. Repeatersand Extenders work on the same channel for this configuration.
This is circualar reasoning? WHY are the satellites acting as Repeaters/Extenders? It's by design choice of Netgear, I assume.
Ragar99
Jan 01, 2019Luminary
Circular reasoning for sure. Furry, time to take you team Netgear hat off and give up.
