tln741
Nov 11, 2017Star
Orbi - why can't we change channels on satellites?
Wireless design best practice when installing multiple access points in an area is to have non-overlapping channels. So if you have 3 APs (RBR50, 2-RBS50) in an area, for 2.4 GHz, one AP would be cha...
Netvllc2000
Apr 25, 2019Guide
I just wanted to add my experience with orbeez I have the same model you do three units and they all use the same channel that I can see on my Wi-Fi analyzer. I have 62 devices connected a handful which are Ness cameras streaming uploading all the time to the cloud gigs of data and all products are working flawlessly! As a technician who installs ubiquity and other consumer and retail networks I can tell you the way or the operates is absolutely phenomenal. Not only is it very strong Works indoors and outdoors and none of my products disconnect I will not question the basic laws of physics that say it shouldn't work on all one channel, but it does.
