ChristineT's avatar
ChristineT
NETGEAR Employee Retired
Jul 19, 2017
Orbi - Wireless Network not available or LED flashing white on Router or Satellite
The NETGEAR team has noticed an issue with upgrading some Orbi Tri-Band WiFi System Model RBK40, RBK43 and RBK30 units in the field to OrbiOS 1.12.0.18.  If your Orbi are affected, the symptoms are:
  • LED flashing white on the Router or Satellite
  • Wireless network not available
NETGEAR is working on a fix for this issue.   To our knowledge, this issue doesn’t affect any Orbi RBK50 or RBK53 units.  If your units have successfully upgraded to OrbiOS 1.12 as the vast majority of Orbi units already have, they should be unaffected.  For more information on verifying the firmware version currently installed on your Orbi system please visit: How do I check the firmware version of my Orbi router?
Please contact NETGEAR Support at 1-888 NETGEAR (638 4327) if you have any questions.
In the interim, we have temporarily removed the OrbiOS 1.12.0.18 firmware from our external websites for the RBK40, RBK43 and RBK30 SKUs.
  • I did a manual sync and the two units (base station and one satellite) are now working fine, and the blinkg light light on the satellite has gone away. still running the 1.12.0.18 firmware.
    I wonder if the firmware is causing problems mostly for people with more than one satellite.
  • I have an RBK50 system affected by the 1.12 update. My base would work fine, but the satellite wouldn't be recognized by the base and it greatly diminished the range and overall performance of my system. Downgrading to 1.11 and disabling auto-update via the telnet method got my system back up and running. Anxiously awaiting a newer rev of the f/w to test.
  • After months of waiting the RBS 50 satellite got available in the Netherlands. Initially very excited but now I do not know anymore. Have latest firmware installed.
    I tried to connect the satellite but the ring continues to blink white and than turns into magenta. Even if I place the satellite close to the router (2 meter!!) pairing fails. I am thinking of returning the satellite unless a solution is available.
    I am very disappointed, waited so long but....
    Is there somebody who can help me. Is this issue related to the topic discussed?
    Thanks a lot for your support.
  • The RBK50 router and satellite are auto-updated to fw  V1.12.0.18 with all parameters at default settings and connect to a BT smarthub box. Speed has improved but sadly video streaming on all iOS device  (all six ipads and iphones in my family) constantly dropped every few minutes. Thought it was signal strength and purchased RBW30 as 2nd satellite. I spend 2 hours trying to install it and the thing just kept flashing white and pulsed to solid blue and never shown the solid white stage. Try numerous methods (app, web, hardware reset) according to instructions and forum's advise - could never connect this second satellite.
    Never have so much trouble in installing a router/wifi device. With dropping wifi on iOS device and so much troubles in adding 2nd satellite I simply decided to return the whole thing yesterday. Voting on my feet is the best feedback I can offer to a technically advanced hardware but wrap under a totally unacceptable and poorly implemented software. Perhaps it will get better in 6 months after all us guinea-pig customers have finished the public beta tests for the company.
    • pathfinderf7's avatar
      pathfinderf7
      Unfortunately this last update to the V1.12.0.18 software has caused numerous issues. It was supposed to fix the previous issues, but it appears it has just caused more issues. The only fix I have found that works for a few days is to manually downgrade to the previous version of software. Unfortunately it will automatically update again in a few days. I have had my orbi since February so I am outside the 90 days to get any assistance over the phone. I am still within the 1 year manufacture return policy. I am afraid tjey will just try to exchange mine for a rebuilt one. I am glad to hear that you were able to return yours. They worked fine up until a few weeks ago when they updated the software. Hopefully in the near future they will fix this issue numerous personnel are having.
  • I have this exact issue now as well with my RBK50.  I thought I was one of the lucky few that got by unscathed with the 1.12.0.8 update but about 2 weeks ago I lose my wireless signal about once per day.  Everything runs great, then all wireless signals drop and I have to manually restart the router to get a signal again. Every.Single.Day.  And I'm at 5 months of ownership so can't actually get support any longer without paying.
