lowrisk
Jan 23, 2019Tutor
Orbi : 1Gbs limitation
I bought a NETGEAR RBK53 a while ago, on Amazon it’s advertised as a 3gb/s device. Although I just realise, the LAN and WAN is obviously limited to 1gb/s so what the point of all that ? I have a...
Jan 23, 2019Guru - Experienced User
Marketing. Its a combination of all the wireless connection rates into one on the box speed rating. "Stream and game even faster with up to 3 Gbps combined WiFi speed 2.4GHz (400Mbps†) + 5GHz (866Mbps†) for WiFi devices to connect to the Internet 5GHz (1733Mbps†) dedicated WiFi link for faster data connections between Orbi router and Orbi Satellite"
Over all current wifi routers are limited at the 1Gb max since RJ45 ports are maxed at 1000Mb. Were all waiting on 10Gb RJ45 ports and customer support. Mostly seen at the Enterprise level.
