mlinman
Oct 03, 2019Follower
ORBI- Can it be used with non-Netgear routers?
Hi, I recently bought an Orbi Router/Satelitte system from a friend. I'm just wondering if it should work with any modem or if it has to be Netgear? My modem is Arris.
Thanks in advance for any help! :)
Yes, works with any kind of Modem or ONT.
- Retired_Member
mlinman wrote:Hi, I recently bought an Orbi Router/Satelitte system from a friend. I'm just wondering if it should work with any modem or if it has to be Netgear? My modem is Arris.
You may want to change the title of your post to: ORBI- Can it be used with non-Netgear modems?
Some people also like to use Orbi systems with non-Netgear routers.
To do that, it helps to put the Orbi router into wireless access point modem
