n8roach's avatar
n8roach
Follower
Aug 07, 2017
Orbi & Control 4
I have Google Wifi with 3 wifi points installed at a home with Control 4.  Problem is you can't put Google Wifi in Bridge mode with a mesh system, only works with 1 point.
I am looking at the Orbi AC3000, does anyone know if this will work in bridge mode and with Control 4?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello N8roach
    You can use orbi as your main router or in access point mode behind another router.
    DarrenM
