SunRed's avatar
SunRed
Orbi + Nighthawk
Can I add a Nighthawk 1900 as an extender to the Orbi pair? I've a 6500 sq ft home and would like to keep my current 1900 router and use it as a "dedicated" extender in the Media Room. The Orbi pair ...
  • rhester72's avatar
    Dec 02, 2016
    Not directly, no.  You could give it the same SSID, but you wouldn't be able to take advantage of any sort of router-directed client handoff, and there's no way to link them with backhaul via wireless.
    Rodney
