Zuur
Sep 27, 2017Follower
Orbi + Powerline on one mesh?
I plan to use a 2x Orbi system in my house; there is lots of roaming in the house so the mesh system allowing for devices to seamlessly pass between the two Orbi's will be a big bonus. I live on ...
madbrain
Sep 27, 2017Luminary
I think this would require Ethernet backhaul, which currently is missing from Orbi.
You would use the Powerline devices as a substitute for a long Ethernet cable in your walls.
Orbi satellites currently talk to each other and the router only via Wifi 5 GHz, so this isn't possible yet. Netgear has said they are working on this feature.
I would be interested in this too. Keep in mind powerline AV throughput is much less than advertised. I have some AV1200 devices and I'm lucky to get 100 Mbps in iperf out of them. Much slower than Orbi over Wifi (when it works) which gets 300-400 Mbps from the same machine. And powerline throughput will get worse with distance too, just like Wifi.
